  2. Logic Design
  3. Exit Error in LEC batch mode
  • Subscribers 61
  • Views 17668
archive over 19 years ago
Hi Guys,
I got one problem when I ran lec in batch mode:
$> lec -nogui -ultra -dofile mc_lec.do
In mc_lec.do file, the last command is : exit -f
But somehow, xterm pops up the following messages:
// Command: report message -compare -verbose > reports/mcv2/lec.cmpmsg
// Command: report compare data -class noneq > reports/mcv2/lec.noneq
// Command: report unmapped points -Extra -notmapped > reports/mcv2/lec.notmap
// Command: report compare data -class abort > reports/mcv2/lec.abort
// Command: exit -force
// ERROR [Internal]:
// Exit and report the error to Cadence Customer Support
and can't go back to normal tcsh mode..
And I can't use CTR^C and CTR^X to exit...
Does anyone have the same problem?
James
Originally posted in cdnusers.org by jianyu2000
    Hi James
    Uhm, not something I have seen before. Can you kill the process from another window?
    What version and OS are you running? Current latest is 07.10-p100.
    Is a .lec_dump_stack file created? (do ls -a) If so, can you send it in to mailto:support@cadence.com?
    Chrystian
    Originally posted in cdnusers.org by croy
    Thanks, Chrystian!
    The tool version: lec 06.20-p100 . It seems not the lastest one. And OS is linux RedHat 6.1
    The .lec_dump_stack file is empty, nothing there.
    Actually, the process is finished already. But the proc can't return to normal xterm mode and just hangs in there...
    Hi James
    I just looked at our OS support matrix and I can't find RedHat 6.1 mentioned. The matrix starts at 4.3 (4 years ago). From 4.3 to 5.2, Red Hat support was for 7.x, 8.0, and 9.0.
    Anyway you can run on a machine with a more recent OS? Current supported is EE3.0 and RHEL4.0.
    I would also give 07.10-p100 a shot if you can.
    Chrystian
    Hi Chrystian,
    Sorry for the misleading info. After try 'uname -a', I got the following msg related to my linux:
    "Linux ltis825 2.4.21-32.ELhugemem #1 SMP Fri Apr 15 21:04:31 EDT 2005 i686 i686 i386 GNU/Linux"
    I can use CTRL^Z to stop the process and kill that proc later. I am not sure if there are some problems related memory release when LEC exit from the batch mode..
