  2. Logic Design
  3. how preserve ports when use delete_unloaded_undriven co...
  • Subscribers 62
  • Views 20851
how preserve ports when use delete_unloaded_undriven command
daijin
daijin over 13 years ago
Hi All,
I want use "delete_unloaded_undriven" command to remove un-used pins in subdesign. But when I used this command, it also removed my top-level ports. I've some constant output ports in design that I don't want to remove them. How let RC only remove sub-module un-used pins, but keep the top-level ports?
Thanks.
  • bmiller
    bmiller over 13 years ago
     The usage indicates that top level ports will only be removed if the"-all" option is used.  Are you using this option?
    Usage: delete_unloaded_undriven [-disconnect] [-all] [-force_bit_blast] [-verbose] <design> [> file]
        [-disconnect]:
            only disconnects the constant connected subports/hierarchical pins
        [-all]:
            deletes unused top-level ports also
        [-force_bit_blast]:
            removes individual bits of a bus by bit-blasting the module
        [-verbose]:
            print debug information
        <design>:
            the name of the design to check
  • daijin
    No I didn't use -all option. I write out this command to a file that
    didn't show my top-level ports name. But in write out netlist, all those
    ports assignment are gone.
    Before use this command, netlist show:
    output [41:0] o_data;
    assign o_data[41] = 1'b0;
    assign o_data[40] = 1'b0;
    After use this command, netlist only show:
    But nothing connect o_data[41] and o_data[40]
    I also use commands:
    set_attribute remove_assigns true /
    set_remove_assign_options -ignore_preserve_setting -buffer BUFFXD2BWP35
    -design $BLOCK_NAME
    set_attribute use_tiehilo_for_const unique
    set_attribute ignore_preserve_in_tiecell_insertion true /
    to make sure all constant value connect to tielo cells instead of use
    assignments.
  • bmiller
     Can you tell me what version of RC you are using?
  • daijin
    11.23
  • bmiller
     I suggest you submit a service request for this issue.  I don't believe delete_unloaded_undriven should disconnect constant top level ports.
  • daijin
    Ok. Thanks.
