  2. Logic Design
  3. TIP OF THE MONTH – Sept. 2007: Set-Up Automation
  • Subscribers 61
  • Views 14328
archive over 19 years ago
One requirement in running Equivalence Checking [EC] is to have a proper set-up. This is because, with an incomplete or incorrect set-up users would see false-negative EC result - in other words, non-equivalency and/or abort due to incorrect design/constraints set-up. Thus, users would need to spend some time to debug, understand the cause, and perhaps provide additional set-up if needed.
To prevent and resolve set-up related issues, Conformal EC XL 7.1 has a new algorithm targeted to analyze certain differences in structure and optimization between the Golden and then Revised designs, and then be able to identify what the set-up should be.
Syntax :
       SET ANalyze Option
       [-NOAUTO | -AUTO]
       (Setup Mode)
Description :
       Automatically determines the best place to run the ANALYZE SETUP com-
       mand. In addition, the Conformal software automatically runs the ANA-
       LYZE ABORT command whenever the comparison returns abort points but no
       non-equivalent points.   Note: This is a Conformal 7.1 XL command.
Parameters:
       -NOAUTO        Disables automatic analysis. This is the default.
       -AUTO          Enables automatic analysis.
Example:
// Command: set analyze option -auto
// Command: set system mode lec
// Running automatic setup...
// Remodeled 1 gated-clock DFF/DLAT(s)
// Automatic setup finished
In this example, command “set analyze option –auto” enables Conformal to automatically recognize that synthesis tool has performed clock-gating as part of power optimization process. Thus, it specifies Conformal to remodel the gated-clock structure, allowing a successful verification of RTL versus synthesized gate netlist.
Notice that the tool infers the set-up based only on what is present in the 2 designs. No information is otherwise passed between implementation and verification of the implementation. This is very important to preserve our independent audit and ensure that your EC tool will not miss a common mode error, a critical Conformal philosophy since the beginning. A false-positive EC result - an equivalent result when it should not be - is obviously very undesirable.
Originally posted in cdnusers.org by vincep
