  2. Logic Design
  3. Command to Store, Restore a RTL Compiler session
  • Subscribers 62
  • Views 18175
beginer
beginer over 13 years ago
Are there commands similar to synopsys's save_session and load_session in RTL Compiler.
  • grasshopper
    grasshopper over 13 years ago
     Hi beginer,
     read_db/write_db
    I suggest you familiarize yourself with its options as well
     gh-
  • GinPB
    GinPB over 13 years ago
     hi, i'm running rtl compiler on a remote server, sometimes the connection fail killing the remote terminal and the rc compilar, there is any way to make rtl compiler recover from a crashed session, or make "recovery points"?, the commands read_db/write_db can be used for my problem?
  • grasshopper
     read_db/write_db will do what you are asking for but seem to me like using VNC, nomachine's NX or similar would be a much better approach to address a connection reliability problem
    gh-
