  2. Logic Design
  3. Query Post Synthesis vs. Post PAR verification using Co...
  • Subscribers 61
  • Views 16633
Query Post Synthesis vs. Post PAR verification using Conformal
archive over 18 years ago
Hello all,
I am trying to do a post syntheis(using netgen command after ngdbuild) vs. post PAR verification using Conformal tool. My problem is that I am getting unreachable points in "revised" design. I am using a hierarchical model (i am new to all these) and my .do file for conformal is as below
set log file lec.top_mod_par.log -replace
set naming rule "%s" -register -both
set undriven signal 0 -both
read design -f $XILINX/verilog/verplex/verilog.vc top_mod_ecn.v -golden -keep_unreach
read design -f $XILINX/verilog/verplex/verilog.vc top_mod_par_ecn.v disp_clock_ecn.v -rev -keep_unreach
set sys mode lec
set mapping method -unreach
report black box -detail
add compare points -all
compare
top_mod_ecn.v : obtained using netgen command after ngdbuild on .edif netlist(from Synplify Pro)
top_mod_par_ecn.v disp_clock_ecn.v : obtained using netgen after PAR (using ISE)
a brief result from conformal is below :
// Warning: Golden and Revised have different numbers of key points:
// Golden key points = 80
// Revised key points = 91
// Mapping key points ...
Mapped points: SYSTEM class
Mapped points  PI    PO    DFF    BBOX    Total
Golden              2       28    49       1          80
Revised             2       28    49       1          80
Unmapped points:
Revised:
Unmapped points BBOX Total
Unreachable             11    11
// Command: add compare points -all
// 78 compared points added to compare list
// Command: compare
Compared points    PO    DFF    BBOX    Total
Equivalent                28    49         1        78
// Command: set mapping method -unreach
// Command: report black box -detail
SYSTEM (empty): X_DCM_ADV
I will be very much thankful if someone could give a light on my problem.
ciao,
ali.
Originally posted in cdnusers.org by alihusaini
    Hi Ali
    Unreachables are a problem only if unexpected. In the log you're showing the verification passes (you would get an exit code of '0').
    I would remove '-keep_unreach' and 'set mapping method -unreach' from you dofile to help cut down on the warnings.
    I don't like using 'set undriven signal 0 -both'. See the 'tip of the month' from February 28 to know why.
    You can use 'report verification' and 'set exit code -verbose' to get a clear picture of the result. You can even customize the messaging, like this:
    tclmode
    if {[get_exit_code] == 0} {
    puts "Verification passed. Awesome"
    } else {
    puts "Problem with run. Darn"
    vpxmode
    Chrystian
    Originally posted in cdnusers.org by croy
    Hi Chrystian,
    I am still having the problem. I just wish to flag the black box so as to go away with verification and that is why "keep_unreach" and "set mapping method -unrecah" is used.I am not finding any solution to do so. neither in gui nor though command writng. I just wish to tell the tool that my design have such module and it shoulf flag/ignore them and continue with verification.
    Ali.
    Hi Chrystian,
    Ali.
    Hi Ali
    I don't understand the issue here. The tool is ignoring it and continuing, and the end result is equivalent (you'll get an exit code of '0').
    Please file an SR through http://sourcelink.cadence.com if you're still unclear.
    Cheers,
    Chrystian
