  2. Logic Design
  3. turn off the unmapped test ports, circuits
  • Subscribers 61
  • Views 14883
archive over 18 years ago
Hi there,
I have two netlists. The final one with test ports and circuits inserted. It caused unmapped points. How can I turn them off in Conformal?
Many Thanks
New Conformal User
Joseph
Originally posted in cdnusers.org by jowu
    Hi Joseph
    The typical setup would be:
    add pin constraint 0 scan_en -both
    add ignored output scan_out -both
    You'll also need:
    set flatten model -seq_constant
    set flatten model -gated_clock
    [set system mode lec]
    remodel -seq_constant -repeat
    Chrystian
    Originally posted in cdnusers.org by croy
