  2. Logic Design
  3. lint warning waiver
  • Subscribers 61
  • Views 17701
lint warning waiver
archive over 18 years ago
I was stopped by a HRC lint error when compiling the RTL code. Is there a way that bypasses this and lets lec read all code in ?
Thanks & Best Regards
Joseph
Originally posted in cdnusers.org by jowu
    Hello Joseph
    YOu can change the setting for that rule to warning instead of error with this command.
    SET RUle Handling
    <[ [-Warning | -Error [-CONTinue] | -Ignore | -Note]]
    [[-EXCLude | -INCLude] <-MODule | -DESIGN_FILE | -LIB_FILE> ]>
    [ |-Design | -Library]
    [-Both | -Golden | -Revised]
    (Setup Mode)
    this must be done before reading your design/lib.
    However, I would suggest to review the error to see why it occurs before doing any ignoring .
    regards,
    Jess
    Originally posted in cdnusers.org by jessican
    Use This command line
    set dof abort off
    This command should be used at the beginning of the script. Then the dofile will further proceed to run the next command though the current line flashes an error.
    Siva
    Originally posted in cdnusers.org by oopsrk
