  2. Logic Design
  3. Unmapped point (not-mapped) issue
  • Subscribers 61
  • Views 19525
archive over 18 years ago
Hi i am using conformal 6.1 version to perforam LEC check.i am using LEC for to comapre golden RTL verses Revised netlist.while doing LEC for some modules i got below issues. Unmapped point (not-mapped): (R) 341094 E /u1_spacc_core/U_spacc_core/U_spacc_ciph_sys/U_ciph_data_buffer/U2_mem_dp_128X64_be/sel0/testram1/ram1/ram0/n984_123[176] in similar way i obseved same equal point in Golden RTL also. then i will edit manually using the below option. add mapped points /Revised point /Golden point -noinvert then all unampped points are disapper from my log file. but it is a tedious process if i edit manually that many unmapped with not mapped points. could you please suggest how to avoid this unampped with notmapped points? plz suggest whcih command i need to add my .do file? -Regards sreenivas
Originally posted in cdnusers.org by sreenivasaraov
    Your mapping issue may be resolved by upgrading to a later version of Conformal. The current version is 7.2 and it has many mapping enhancements. If you have an XL license you can "set analyze option -auto" (new in 7.1) and "set flatten model -seq_constant". This will resolve many modeling issues which can lead to mapping problems. Here is an example:
    set system mode lec
    add compare point -all
    compare
    -Noel
    Originally posted in cdnusers.org by nstjohn
    hi thank q Noel. But "set analyze option -auto" option was not supported by 6.1 version.if i add manually this unmapped with not mapped points it is a tedious process.so could you please suggest some other alternative to avoid this unmapped with not mapped points?
    Hi Sreenivas
    the unmapped is E gate. are you certain they are also existing in the golden (RTL side)? i would think NOT since by default, conformal will treat x (don't care) in golden as DC, and revised as E gate, unless you change the setting (set x conversion) However, if they are exactly the same (in name), they should be mapped. Can you also posted the name of the unmapped in the golden?
    regards,
    Jess
    Originally posted in cdnusers.org by jessican
