  2. Logic Design
  3. inverted equivalent points
  • Subscribers 61
  • Views 18861
archive over 18 years ago
what r inverted equivalent points? how we will come to know some points are inverted equivqlent?
Originally posted in cdnusers.org by sujittikekar1
    An inverted equivalent point is one that has the phase inverted.
    Let's say you have a flop with an inverter in front of it. You may get slightly better synthesis results by pushing that inverter through the flop, to its output. Also necessary: flipping any asynch set and/or reset pins.
    Quite a few customer will NOT allow synthesis to do this since it affects a lot of post-synthesis processes and to QoR improvement may not be real.
    Conformal will look for flops with inverted phases only when 'set mapping method -phase' is used. You can also do it manually using 'add mapped point -invert'.
    Chrystian
    Originally posted in cdnusers.org by croy
