  2. Logic Design
  3. Clock gating
  • Subscribers 61
  • Views 15758
Clock gating
archive over 18 years ago
I ran incremental synthesis to add clock gating on top of the original netlist. I also have scan-enables going into the ICG's. What would be the best way to run Conformal? I come up with the following setup. // inactivate scan add pin constraint 1 Scan_en_n -both add pin constraint 0 Scan_test -both set flatten model -gated_clock
Originally posted in cdnusers.org by cosifan
    Hi cosifan
    You may also want to add 'set flatten model -seq_constant' and 'add ignored out scan_out* -both'.
    Chrystian
    Originally posted in cdnusers.org by croy
