  2. Logic Design
  3. set_false_path -through and set_load on the output port...
  • Subscribers 62
  • Views 2675
set_false_path -through and set_load on the output ports
beginer
beginer over 13 years ago
If i have set false paths through all the output ports and also specified a specific load on the output ports, will rccompiler/encounter optimize these paths to meet the DRV's that arise because of the specified load or will they ignore them as these paths are false
  • grasshopper
    grasshopper over 13 years ago
     Most tools will ignore false paths for DRVs but I cannot say this is 100% consistent across tools and vendors. The lack of consistency in itself is probably a good reason in intself to tread very carefully if that is going to be your assumption
     gh-
