  2. Logic Design
  3. Error with Vendor-contributed Models in Simulation
  • Subscribers 62
  • Views 15303
sns22
sns22 over 13 years ago
I wanted to use AD8002 opamp in my design so I used  the Vendor-contributed Models libraries from the downloads page here http://www.cadence.com/products/orcad/pages/downloads.aspx in the design to get this component. But I am getting a
ERROR(ORPSIM-15108): Subcircuit AD8002AR/AD used by X_U1A is undefined for this opamp.
Am I missing something?Is there something else I need to do in order to use this component?
I am using Orcad Capture CIS Lite Edition 16.6-p001 (v16-6-112A)
Sneha
  • oldmouldy
    oldmouldy over 13 years ago
    You need an OLB file for the graphical symbols and a LIB file for the model information for simulation. It sounds like you either don't have the simulation, LIB, file or you need to add it to the Sumulation Profile, PSpice>New, or Edit, Simulation profile, Configuration Files tab, Library on the left, use the upper browse button to browse to and select the LIB file, use Add to Design to add the LIB file to the Simulation Profile, OK the dialog and you should then be able to simulate the circuit.
