  2. Logic Design
  3. module naming with hexadecimal values
  • Subscribers 61
  • Views 16026
Rafeeq2129
Rafeeq2129 over 13 years ago
  Can anyone help me with the command for LEC-XL to generate  modules with Hexadecimal values (instead of Decimal) of inputs signals ?
  Example :
  1.)   add #( x(23) , y (1'h0) , z(1)) (.clk (clk) .reset(rst))
      LEC output  :    add_x23_y0_Z1
  2).  applied renaming rule :  set naming rule -parameter "_"
       LEC ouput  :  add_23_0_Z1
   3).  Desired output :  add_23_000000_Z1
          Command required to generate module name as above .
regards
rafeeq
  • grasshopper
    grasshopper over 13 years ago
     I believe LEC relies on the way the fields are defined. In your case, your definitions do not match what your expectations are hence LEC has no way of guessing what it is that you want
    gh-
  • tstark
    tstark over 13 years ago
     LEC's renaming currently support decimal searches only. I imagine you could get creative and make a hex search but depending on your needs this could get difficult or impossible.
    -ts
