  2. Logic Design
  3. How do I delete clock groups (created via set_clock_groups...
  • Subscribers 62
  • Views 16451
How do I delete clock groups (created via set_clock_groups)
moogydmaxim
moogydmaxim over 13 years ago
I have been using set_false_paths between clocks, and found out that it is better to use clock groups using set_clock_groups. Therefore, I updated my SDC files, but I now have a slight issue.
 I use RTL compiler to do some sanity checks of SDC prior to handoff. In pseudo code
read netlsit
for sdc in func1.sdc func2.sdc scan.sdc loop
   reset_design
    read_sdc
    timing lint, timing reports etc
     write_sdc -strict
 endloop
Previously, this has worked well, but it seems that clock_groups cannot be deleted. In the above, reset_design leaves the clock groups untouched, therefore my exported SDC files have clock groups for clocks that may not exist.
As an experiment, I also rm /design/my_design and reloaded - the clock groups were still not deleted !
Any ideas?
Steven
  • grasshopper
    grasshopper over 13 years ago
     Hi Steven,
     this was a bug and has been addressed in recent releases. If you need a workaround for an older release, please work with your AE or support contact for more details.
    For reference for you AE or support, CCR: 1145910
    regards,
    gh-
