  2. Logic Design
  3. Creating a reset scan test using Encounter Test
  • Subscribers 62
  • Views 14877
glennramalho
glennramalho over 13 years ago
Has anyone seen this problem? I have been trying to create a script for running Encounter Test using TCL. In the script I wrote the line:
create_reset_tests WORKDIR=directory TESTMODE=FULLSCAN EXPERIMENT=resettest
Then I ran the script by doing:
% et -tcl
% source file.tcl
And then I get the error message:
invalid command name "create_reset_tests"
    while executing
"create_reset_tests ....
But I then copy-and-paste the exact line from the script file into the window it works. The same happens if I call "et -source file.tcl" instead. It seems the command cannot be invoked from the scripts.
The version is: Encounter(R) Test and Diagnostics 10.1.103 Jun 21, 2011 (linux26_64 ET101)
