  2. Logic Design
  3. RTL compiler command for retaining design hierarchy
  • Subscribers 63
  • Views 18711
dkhan
dkhan over 13 years ago
Is there a command in RTL compiler which can force the synthesizer to retain original hierarchy of the design, like there is in Xilinx ISE for instance?
Thanks.
  • grasshopper
    grasshopper over 13 years ago
     Hi dkhan,
     I just used the RC apropo command and assume one of the following attribute is what you are looking for
    rc:/> apropo ungroup
    Commands matching search string:
      edit_netlist ungroup
      ungroup
    Commands with help text matching search string:
      ungroup
    Commands with option text matching search string:
      edit_netlist
      ungroup
    Attributes matching search string:
      auto_ungroup (root)
      auto_ungroup_min_effort (root)
      auto_ungroup_ok (subdesign)
      dp_ungroup_separator (root)
      ungroup (hdl_arch)
      ungroup (hdl_comp)
      ungroup (hdl_impl)
      ungroup (hdl_inst)
      ungroup_ok (instance)
    Attributes with help text matching search string:
      auto_ungroup (root)
      ungroup (hdl_arch)
      ungroup (hdl_comp)
      ungroup (hdl_impl)
      ungroup (hdl_inst)
    I am assuming you need
     set_attr auto_ungroup false /
    gh-
  • dkhan
     Thanks a lot grasshopper!
