  2. Logic Design
  3. What does Constant hierarchical Pin(s) means in RTL compiler...
  • Subscribers 62
  • Views 9108
What does Constant hierarchical Pin(s) means in RTL compiler?
Bardia B
Bardia B over 13 years ago
Hi everybody,
When I check the design in RTL compiler 10.1 after synthesis, I get the following summary for my design.
I know that Assigns are not good and should be removed before importing the design in SoC encounter and I know how to do it.
But my question is about the Constant hierarchical Pin(s). I don't know what those mean and if they are important? Should they also be removed before place and route? And how?
Name Total
Unresolved References 0
Empty Modules 0
Unloaded Port(s) 0
Unloaded Sequential Pin(s) 0
Assigns 83
Undriven Port(s) 0
Undriven Leaf Pin(s) 0
Undriven hierarchical pin(s) 0
Multidriven Port(s) 0
Multidriven Leaf Pin(s) 0
Multidriven hierarchical Pin(s) 0
Multidriven unloaded net(s) 0
Constant Port(s) 0
Constant Leaf Pin(s) 3
Constant hierarchical Pin(s) 297
Preserved leaf instance(s) 0
Preserved hierarchical instance(s) 0
Libcells with no LEF cell 0
Physical (LEF) cells with no libcell 27
Thanks in advance for your help.
 Bardia
  • bmiller
    bmiller over 13 years ago
     Constant hierarchical pins are generally not a problem, but they are still worth investigating.  When RC propagates constants across hierarchical boundaries, it will tie the pin to 1'b0.  The other side of that hierarchical pin will have nothing attached to it.  It effectively becomes an unused hierarchical pin, but RC, by default, will tie it off so it is not undriven.
     What you need to do, to further investigate, is run "check_design -constant" and look at any constant hierarchical pins have a fanout greater than 0.  A fanout of 0 means that it is an unused hier pin, which is not an issue.  For example:
    design 'dtmf_chip' has the following constant input hierarchical pin(s)
    /designs/dtmf_chip/instances_hier/JTAG_MODULE/pins_in/JTAG_SE      (fanout : 5)
    /designs/dtmf_chip/instances_hier/JTAG_MODULE/pins_in/JTAG_TEST_ENABLE      (fanout : 4)
    /designs/dtmf_chip/instances_hier/JTAG_MODULE/pins_in/JTAG_IOTEST      (fanout : 1)
    /designs/dtmf_chip/instances_hier/JTAG_MODULE/pins_in/JTAG_TEST_CLOCK      (fanout : 1)
    /designs/dtmf_chip/instances_hier/JTAG_MODULE/pins_in/JTAG_INSTR_CAPTURE_2      (fanout : 1)
    /designs/dtmf_chip/instances_hier/JTAG_MODULE/pins_in/JTAG_POR      (fanout : 1)
    /designs/dtmf_chip/instances_hier/DTMF_INST3/pins_in/tdsp_pso      (fanout : 0)
    /designs/dtmf_chip/instances_hier/DTMF_INST3/pins_in/int      (fanout : 0)
    /designs/dtmf_chip/instances_hier/DTMF_INST2/pins_in/tdsp_pso      (fanout : 0)
    /designs/dtmf_chip/instances_hier/DTMF_INST2/pins_in/int      (fanout : 0)
    /designs/dtmf_chip/instances_hier/DTMF_INST1/pins_in/tdsp_pso      (fanout : 0)
    In this case, some of the JTAG_MODULE pins are tied off, which I expect, and all the rest of a fanout of 0.  No problems here.
