  2. Logic Design
  3. how to identify unique nets connected to preset/clear pins...
  • Subscribers 62
  • Views 1832
how to identify unique nets connected to preset/clear pins of all FFs in a scope
Sporadic Crash
Sporadic Crash over 12 years ago
I have not been able to find an attribute that shows whether a net in a scope is connected to a preset/clear of FF.
The only way I have found:
foreach FF in a scope {
 foreach pin of this FF {
  if { libpin of this pin is a {async_clear} } { set an async_clear net }
  if { libpin of this pin is a {async_preset} } { set an async_preset net }
  if { libpin of this pin is a {sync_clear} } { set a sync_clear net }
  if { libpin of this pin is a {sync_preset} } { set a sync_preset net }
This is quite complicated, because in a certain block there can be several FFs each of which can be resetted in a different way, thus HW designer might need to create a TCL associative array to identify unique nets.
Is there an easier way to do this?
  • grasshopper
    grasshopper over 12 years ago
     Hi Sporadic Crash,
     logical nets have 'driver' and 'loads' attributes
     instances have a libcell attribute
     libcell have attributes async_clear, async_preset, sync_clear, sync_preset
     That should provide all the pieces of needed solution
    gh-
