  2. Logic Design
  3. Conformal- LEC
  • Subscribers 62
  • Views 3085
Conformal- LEC
Indira S
Indira S over 12 years ago
Hi When I run Hirarchial compare using conformal, write hier_compare dofile dofile.do is not created. It is throwing the error like "could not find the starting comment hierarchial do file generated by conformal when I run run hier_compare. When I setup the design I got the message like $ modules are output for Hierarchial do file yet the do file is not created. What may be the reason? I just used a simple verilog design.
  • tstark
    tstark over 12 years ago
    Make sure to use "write hier_compare dofile -run_hier" when running "run hier_compare". They work together. Also when using "run hier_compare" the hier dofile can't be edited.
    There are sample dofiles in the web interface:
     SETUP/LEC> set web on
    -ts
