  2. Logic Design
  3. conformal -Lec
  • Subscribers 62
  • Views 5369
conformal -Lec
Indira S
Indira S over 12 years ago
I am verifying a RTL vs NEtlist created by synopsys DC compiler. Some modules are black boxes by the tool. I think they are some memory modules. What is the way to preserve the interface information of the black box ie only the boundary info.
  • tstark
    tstark over 12 years ago
     The command is "add notranslate modules <module> -both". Use it before design library read-in. Often the term "black boxing" means using "add notranslate modules"
     It is useful for memories, analog circuits, and "non-synthesizeable" code. If you don't "add notranslate module" to large memories then you can have problems with excessive run-time and server memory.
    It is also useful to check what is black boxed after read-in with the command "report black box".
    There are more examples, "troubleshooting info", etc. if you search http://support.cadence.com
    -ts
