  2. Logic Design
  3. Help on LEC failure between compile netlist vs. compile_incr...
  • Subscribers 62
  • Views 14711
Help on LEC failure between compile netlist vs. compile_incr netlist from DC
r u verified
r u verified over 12 years ago
Need a help on LEC: my LEC is clean between RTL vs. first compile netlsit from DC; however it failed on 30 points between RTL vs. compile_incr netlist.. I further did a gate-level LEC between compile netlist and compile_incr netlsit, but still same failing points as RTL vs. compile_incr.  What could be the root cause of it and how to clear?
Appreciated any good advice/suggestions!
Bryan
