  2. Logic Design
  3. clock gating in RC
  • Subscribers 62
  • Views 16986
clock gating in RC
doydodo
doydodo over 12 years ago
Hello.
What is the right way to insert clock gating in RC script?
How should i translate the following instructions form DC for RC ?
(DC) -->
set_clock_gating_style -sequential_cell latch \
  -negative_edge_logic $CELL_NAME \
  -positive_edge_logic $CELL_NAME \
  -max_fanout 16 \
  -minimum_bitwidth 4 \
  -control_point before \
  -control_signal scan_enable
(RC) -->
define_dft shift_enable -name scan_enable -active high $CELL_NAME1
define_dft shift_enable -name scan_enable -active low $CELL_NAME2
set_attr lp_insert_clock_gating true
set_attr lp_clock_gating_min_flops 4 [find/design -design $DESIGN]
set_attr lp_clock_gating_style latch [find/design -design $DESIGN]
set_attr lp_clock_gating_control_point precontrol [find/designs -design $DESIGN]
set_attr lp_clock_gating_test_signal scan_enable $DESIGN
 Is it enough or there is something else needed?
  • bmiller
    bmiller over 12 years ago
     That looks right.  If you want to limit the fanout of the clock_gater to 16, then you will also want to add the lp_clock_gating_max_flops attribute, and set it to 16.  However, I think it is better to let the PnR tool clone the clock gaters, if necessary, to meet timing to the enable signal.
    Also, be sure you set the lp_insert_clock_gating attribute to true BEFORE you read and elaborate your RTL.
