  2. Logic Design
  3. how to synthesize delay elements in RTL complier
  • Subscribers 62
  • Views 17972
micro469
micro469 over 12 years ago
hi there,i am new to RTL compiler. I have delay element to synthesize in which the  input is assigned to output after some delay  .The state ment  i used shown below.
assign #5 out=in;
But when i am synthesizing in RTL the delay is ignored. So are there any attributes i have to add to synthesis delays in RTL compiler? if not is there any other way to make delay elements? . I would be greatful to if you include sample code or snippet. Thanks in advance.
  • grasshopper
    grasshopper over 12 years ago
    Hi micro469,
     delay elements are not synthesizable. They simply get ignored by synthesis tools. Delay cells normally require hand-instantiation and dont_touch attributes since they serve no functional purpose
     gh-
  • micro469
    Thanks grasshopper . could you please give a small  code snippet for hand instantiation .
  • grasshopper
     mydly DLYX1 (.IN (my_net), .OUT(my_out_net) );
     where DLYX1 is a delay cell from the library
    hope this helps,
    gh-
