  2. Logic Design
  3. RTL compiler error
  • Subscribers 62
  • Views 15576
RTL compiler error
Jinesh K B
Jinesh K B over 11 years ago
Sir, am getting this message when using RC.After showing this message tool is not responding.My other designs are working fine.But for this program sad1.vhd am getting correct output in NCSIM (also I was able to synthesize the design in xilinx ISE) so what may be the problem.
 Elaborating top-level block 'SAD' from file 'sad1.vhd'.
  Done elaborating 'SAD'.
        Trying carrysave optimization (configuration 1 of 1) on module 'SAD_csa_cluster_104'...
Info    : Done carrysave optimization. [RTLOPT-20]
        : There are 2 CSA groups in module 'SAD_csa_cluster_104'... Rejected.
        Trying carrysave optimization (configuration 1 of 2) on module 'SAD_csa_cluster'...
        : There are 16 CSA groups in module 'SAD_csa_cluster'... Rejected.
        Trying carrysave optimization (configuration 2 of 2) on module 'SAD_csa_cluster'...
        : There are 17 CSA groups in module 'SAD_csa_cluster'... Rejected.
        : There are 2 CSA groups in module 'SAD_csa_cluster'... Accepted.
        : There are 10 CSA groups in module 'SAD_csa_cluster'... Accepted.
Mapping SAD to gates.
  • grasshopper
    grasshopper over 11 years ago
    how long did u wait ?
    if u truly have a hang you will need to contact your AE or file a support ticket through support.cadence.com
    regards,
    gh-
