  2. Logic Design
  3. Conformal LEC hier_compare only on 1 module
  • Subscribers 62
  • Views 19291
Matt Hutson
Matt Hutson over 11 years ago
Hi,  so having a long history of using another vendors tools I am re/learning cadence ones.
Basically I have done an ECO at a sub-module.
I have rtl with the ECO and 1 big netlist of the top with the ECO. Luckily from a intermediate RC step with hierarchy.
So I tried an elaborate of the sub module. Which shows that the altered endpoints are ok, but fails for other optimized outputs across the hierarchy.
The full run takes 39 to 68 hours with heir_compare. The sub module takes 3 minutes.
Just need a clue as to what command to look at to analyze the sub module in context of the top.
Obviously I am now re-running the full top check to make sure nothing else has been affected.
  Matt
  • Matt Hutson
    Well answering my own post. I found a couple of commands.
    write hier_compare  -noexact_pin_match -constraint -usage -replace -balanced_extraction -input_output_pin_equivalence \
    -MODULE <golden_module> <revised_module>
    run hier_compare -ROOT_module <golden_module> <revised_module>
    For this design it has the similar affect as previous run:
    elaborate design -golden -root <golden_module>  -rootonly
    The heir_compare might mean some constraints would be passed down,
    and less modification to script for constraints at higher level though.
    However bit surprised the constant/unused flop removal is not worked out before heir compare.
    Of course I could still have missed some extra commands that might help.
  • Matt Hutson
    This has a similar affect as :
    and compare.
    With heir_compare the script does not need to be changed so much at least.
    I was hoping that the constraints would also be passed down.
    However was a bit surprised the constant/unused flop removal is not worked out before heir compare.
    Of course I could still have missed some extra commands that might help ignore the unused outputs.
