  2. Logic Design
  3. LEC - MOS direction and abstract logic error
  • Subscribers 62
  • Views 1270
sacmax
sacmax over 11 years ago
I am trying to convert a schematic to RTL and get a logical equivalence between them. The level shifter in the schematic has a couple of nmos and pmos transistors. For one of the transistors, I am getting the error:
// Error: Instance 'NM0' in module 'xyz' in Revised is bi-directional.
// Error: Assign MOS direction with ADD MOs Direction command.
// Error: Use automatic logic abstraction with ABStract LOgic command.
My company does not have the GXL license so I cant use the above commands. I tried black boxing the level shifter but the circuit at its output fails equivalence. Is there any other way to work around this?
sacmax
