  2. Logic Design
  3. RTL Compiler synthesis with inference to a custom cell
  • Subscribers 62
  • Views 16780
jjgs
jjgs over 11 years ago
I want to synthesize with inference to a custom cell. Like, in the below, instead of plain vanilla latch from foundry cell library, I want to infer my custom latch. How can I do that? I've heard of "// synopsys dc_script_begin" and "// synopsys dc_script_end"  but I am not sure how and if, at all. Any help/hint is appreciated.
    always @*
        if(!RESETN) Q = 0;
        else if(EN)    Q = D;
  • grasshopper
    grasshopper over 11 years ago
    Hi jjgs,
    under what condition will you get custom cell and under what conditions will you get regular latch.
    There are many options here and I will briefly mention a few you can dig further:
    (1) RC/Genus indeed support dc_script_begin/end although not clear how you were told to use it
    (2) There is also pragma map_to_module
    (3) Chipware developer allows to link chipware to synthetic operators
    (4) Can EASILY use change_link command after mapping (i.e identify latches that need to be relinked and swap them)
    (5) Even EASIER, and provided pin names map, change libcell attribute of the library latches
    hope this helps,
    gh-
