  2. Logic Design
  3. do I need to use write_hdl -lec for equivalence check ?
  • Subscribers 62
  • Views 1674
zczc99
zczc99 over 11 years ago
I am new to conformal lec check.  I am trying to do rtl-to-gate equivalence check with Conformal 15.10.
The netlist is written from RTL compiler with write_hdl > design_syn.v, and it failed with the checking.
But if I use  write_hdl -lec > design_syn_lec.v, the conformal check can pass.
Is there any reason behind this?
Which netlist should I use for place & route ?
Thank you
  • grasshopper
    grasshopper over 10 years ago
    Use output of write_hdl for P&R
    write_hdl -lec adds additional annotation in some cases hence passing. It is all in text form and you should easily see it
    gh-
