  2. Logic Design
  3. How to connect a common test port to all the CG cells for...
  • Subscribers 62
  • Views 15871
How to connect a common test port to all the CG cells for clock gating?
zczc99
zczc99 over 11 years ago
I am using clock gating during synthesize with RTL compiler. Now I can insert the CG cells, but the 'test' port is connected to GND.
I have a test port 'CG_test_mode', but I don't know how to connect this port to all the test pins of CG cells.
Anybody knows?
Thank you
  • grasshopper
    grasshopper over 10 years ago
    Please review LP user guide. You need to set the attribute
    lp_clock_gating_test_signal
    and prior to its use the command
    define_dft test_mode
    if not in use already
    regards,
    gh-
