  2. Logic Design
  3. check clock_gating gives 0 gated flip-flops after synth...
  • Subscribers 62
  • Views 17950
check clock_gating gives 0 gated flip-flops after synthesize
zczc99
zczc99 over 10 years ago
I am using RTL compiler to synthesize my design, and I want to implement clock gating in my design.   Here is part of the constraint
set_attribute lp_insert_clock_gating true /
read_hdl -v2001  $myfiles ;
elaborate $basename ;
# clock gating constrain
set_attribute lp_clock_gating_prefix {CG_CHAO_}
set_attribute lp_clock_gating_exceptions_aware true /
set_attribute lp_clock_gating_module ICG_posedge [dc::current_design]
synthesize -to_clock_gated
synthesize -to_mapped -effort high
And it works, when I use report clock_gating, I can see about 70% flipflops are gated.
But I want to connect all the 'test' pins of ICG cells to CG_always_on port, so I added several lines before synthesize.
define_dft  test_mode -active high [find / -port CG_always_on] -name CG_always_on
set_attr lp_clock_gating_test_signal CG_always_on [dc::current_design]
Then after synthesize -to_clock_gated, check  clock_gating gives 579 gated flipflop.
But after synthesize -to_mapped -effort high, check  clock_gating gives 0 gated flipflop. In netlist, actually there do have gated flipflops.
What is wrong with this?
  • grasshopper
    grasshopper over 10 years ago
    Please try 15.x and report back if you still see the same issue
    gh-
  • zczc99
    Hello grasshopper,
    I tried v14.20-s016_1, still the same. But I don't have v15 version.
  • grasshopper
    Not sure what you expect to see here. The report looks correct. Inserting clock gating will not change this report. You can model the latency using set_clock_latency constraint but clocks in RC/Genus are ideal hence nothing to show in the report. Please show the output you would like to see if you disagree
    gh-
