  2. Logic Design
  3. clock gating timing report with synthesized ICG cell
  • Subscribers 62
  • Views 19185
zczc99
zczc99 over 10 years ago
Hi guys,
I am using clock gating in cadence RTL compiler, but there is no ICG cell in the library. So I implemented an ICG cell with verilog code, which is active high ICG cell.
module ICG_posedge(
  input ck_in,
  input enable,
  input test,
  output ck_out
reg en1;
wire tm_out, ck_inb;
assign tm_out = enable | test ;
assign ck_inb = ~ck_in;
always @(ck_inb, tm_out)
      if(ck_inb)
        en1 = tm_out;
assign ck_out = ck_in & en1;
endmodule
after insertion of clock gating, the timing report seems didn't take the gating into account.
For example, here the clock stop_HF is the non-gated clock, but the 2 flops both are clock gated. it seems that the ICG cell is transparent to the timing report, and has no effect on the launch and capture clock path.
Do I need some constraint to make timing analysis take ICG in to account?
Thank you
