  2. Logic Design
  3. RTL Compiler command questions: pwd, multicore options,...
  • Subscribers 62
  • Views 17690
RTL Compiler command questions: pwd, multicore options, and program name
menime54
menime54 over 10 years ago
We are switching over to RTL Compiler.  I am moving our scripts over to the RTL Compiler flow.
1)  When I type pwd into RTL Compiler I get back /  .  I need the path where I started RTL Compiler, similar to doing a pwd in linux.  Is there a command to get the full path and not just the path from where you started RTL Compiler?
2)  The following option is not available in RTL Compiler.  How do I set the multicore CPU option in RTL Compiler?
set_host_options -max_cores 2
3)  Is there an RTL Compiler command that is similar to the synopsys command:  synopsys_program_name
Stephanie
  • grasshopper
    grasshopper over 10 years ago
    Hi Stephanie,
    (1)
    To determine the path in the unix hierarchy where RC/Genus is executing, the command is
    lpwd  (stands for local pwd)
    pwd would point to the RC (or Genus legacy mode) internal hierarchy
    (2)
    attribute is 'max_cpus_per_server'
    In addition, user can also configure attribute 'super_thread_servers' when using multiple hosts
    (3)
    I am assuming this does the same as
    legacy_genus:/> get_attr program_name /
    Genus(TM) Synthesis Solution
    legacy_genus:/> get_attr program_short_name /
    genus
    legacy_genus:/> get_attr program_version /
    15.10
    legacy_genus:/> info nameofexecutable
    /home/tools/15.10/bin/linux/genus
    hope this helps,
    gh-
