  2. Logic Design
  3. RTL Compiler functions with regexp
  • Subscribers 63
  • Views 17367
menime54
menime54 over 10 years ago
I am trying to use the get_libs command with a regular expression.  The following is returning an error for me as the regular expression is not working.  It is trying to evaluate [sft] instead of using it in the regular expression.  How do I write this line of code to work properly?
[get_libs -regexp "scs8ls_[sft][sft]_.*"]
rc:/> [get_libs -regexp "scs8ls_[sft][sft]_.*"]
invalid command name "sft"
Stephanie
  • grasshopper
    grasshopper over 10 years ago
    Hi Stephanie,
    this is standard TCL behavior. If enclosed in double-quotes, you will need to escape the [] characters. In general regexps can be expensive to use in tools. They are extremely useful indeed but sometimes there are better alternatives in terms of performance
    gh-
  • menime54
    Hi Grasshopper,
    Originally I tried this with the escape characters, but it does not work.  What am I doing wrong?
    rc:/> [get_libs -regexp "scs8ls_\[sft\]\[sft\]_.*"]
    Warning : Could not find requested search value. [SDC-208] [get_libs]
            : The 'get_libs' command cannot find any libraries named 'scs8ls_[sft][sft]_.*'.
  • grasshopper
    This is kinda tricky since SDC provides an application note with commands and options but nothing on semantics, etc.
    Here is how you can make it work in Innovus and Genus. I believe Innovus is 'more' correct in this case. I believe Genus is too strict in interpreting as literal when using {} to protect string
    [DEV]innovus 5> get_libs -regexp {r[ao]m.*}
    ram_256x16_slow rom_512x16A_slow ram_256x16_fast rom_512x16A_fast
    0x18
    genus@root:> get_libs -regexp "r\\\[ao\\\]m.*"
    library:wc0d99com/ram_256x16_slow library:wc0d99com/rom_512x16A_slow
    Using {} in Genus will result in nothing found since [] gets interpreted as literals. The downside of the innovus approach would be looking for libraries that have literal [] in their name would then likely require escapes, etc.
    hope this helps,
    gh-
