  2. Logic Design
  3. Adding pg pins to a netlist
  • Subscribers 63
  • Views 19788
deeps4
deeps4 over 10 years ago
Is there a command or switch in RTL compiler that will add pg pins also in the synthesized netlist. This can be done at encounter but wanted to know if same result can be achieved in RTL compiler.
-DN
  • Fotios Nt
    Fotios Nt over 10 years ago
    Hello DN,
    I don't think there's a way to do what you want apart from either inserting the pg pins yourself in the RTL(bad idea for many reasons), or forcing reading in libs/lefs that have pg pin information
    Best Regards,
    Fotis
  • grasshopper
    grasshopper over 10 years ago
    To previous point in thread, what is the purpose of doing that?
    gh-
  • deeps4
    Thanks Fotis. Yes inserting in RTL is not a good approach and also modifying the netlist through scripting is also not a good idea. So just wanted to know if it can be done via RTL compiler.
  • deeps4
    To make a lower level IP compatible for running an AMS simulation at SOC level. This is needed just for simulation purpose before pnr.
