  2. Logic Design
  3. Scannable DFT shadow-logic insertion with register sharing...
  • Subscribers 62
  • Views 19658
Scannable DFT shadow-logic insertion with register sharing around FIFOs by adding clock gating on main test clock
Pacher Luca
Pacher Luca over 10 years ago
Dear all,
I'm currently trying to add scan-chain testability to a design that includes memories implemented with FIFOs. All FIFOs in the design are described at RTL-level using FlipFlops as basic storage elements, hence all these memories are fully-synthesized along with the remaining top-level logic. Since I'm not interested in replacing all FlipFlops of FIFOs with scannable FlipFlops part of the scan-chain, I'm trying to insert shadow logic around them using the insert_dft shadow_logic command. Furthermore I'm only interested in by-passing all FIFOs inputs (my application doesn't require MBIST features for FIFO inputs). Nevertheless I want to make at least FIFOs outputs scannable. Hence my choice was to add scannable shadow-logic with register sharing as described in Design for Test in Encounter RTL Compiler documentation, pp. 220-224. Everything in the Cadence recommended flow works fine up to final scan-chain connection with a satisfactory percentage of ATPG coverage. At the end of the synthesis flow all FIFOs outputs are properly multiplexed with insertion of additional scannable-FlipFlops.
Due to a pad-count limited design the test clock adopted for the scan-chain and defined during the DFT setup is simply the main system clock. Indeed, with such a flow all extra-FlipFlops added by shadow-logic insertion introduce a lot of unwanted extra switching-power due to shadow FlipFlops always connected to the main clock. As a result, I would like to add clock gating to all extra FlipFlops inserted by RTL Compiler during shadow-logic insertion around FIFOs. I tried to perform this at RTL-level by hand, thus I've added an extra, unconnected input port clk_shadow in my design, which in turn is the main system/test clock with a test-mode controlled vetoing  (clock gating is performed in the top-level wrapper with a dedicated latch/and block, I dont't care for the moment about this) . The clk_shadow signal is defined as an auxiliary test clock during the DFT setup, along with the main system/test clock clk :
define_dft \
   test_clock                       \
   -name              scan_clk      \
   -period            25000.0       \
   clk
define_dft \
   test_clock                       \
   -name              shadow_clk    \
   -period            25000.0       \
   -controllable                    \
   clk_shadow
Since at the end of the flow I want to connect all scannable-FlipFlops into a unique scan-chain (including shadow-logic FlipFlops) both clocks are declared as part of the same test-clock domain
set_compatible_test_clocks -all
as suggested in
community.cadence.com/.../24651
After generic synthesis I run the insert_dft shadow_logic command and I specify as test clock the clk_shadow signal, as follows:
insert_dft \
   shadow_logic                                \
   -mode             share                     \
   -around           [find / -instance Fifo*]  \
   -test_control     scan_mode                 \
   -test_clock_pin   clk_shadow
After mapped synthesis I've two scan chains in my design, the first one directly driven by the system/test clock, the second one driven by the "clock-gated by hand at top-level" shadow-logic clock. Finally I run the connect_scan_chains command to merge scan-chains and thanks to the fact that the two clocks are into the same clock domain all extra shadow-logic scannable FlipFlops are connected into a unique scan-chain with others scannable FlipFlops driven by the system/test clock.
Actually, I'm not happy with such a solution that requires extra "tweaking" to RTL. I had a look to the insert_dft scan_power_gating command but its effective usage and application is not clear to me.
Can anyone suggest me the right way to add clock gating to all extra-FlipFlops part of a shadow logic structure?
Thanks in advance
Luca
