  2. Logic Design
  3. Module name change after synthesis in RTL compiler
  • Subscribers 62
  • Views 18143
manideepa
manideepa over 9 years ago
I am trying to synthesize VHDL files using RTL compiler and created the netlist file. My design is hierarchical with submodules. However, the netlist created with a submodule name. Is it due to some optimization? How can I change this? My script is as below
set_attr lib_search_path /cad/FOUNDRY/digital/90nm/dig/lib
#set_attr hdl_search_path ../rtl/
set_attr library /cad/FOUNDRY/digital/90nm/dig/lib/slow.lib
read_hdl -vhdl {/home/manideepam/NOC/my_package.vhd /home/manideepam/NOC/my_switchcontrol.vhd /home/manideepam/NOC/my_buffer.vhd /home/manideepam/NOC/my_crossbar.vhd /home/manideepam/NOC/RouterBL.vhd /home/manideepam/NOC/RouterBC.vhd /home/manideepam/NOC/RouterBR.vhd /home/manideepam/NOC/RouterCC.vhd /home/manideepam/NOC/RouterCL.vhd /home/manideepam/NOC/RouterCR.vhd /home/manideepam/NOC/RouterTL.vhd /home/manideepam/NOC/RouterTR.vhd /home/manideepam/NOC/RouterTC.vhd /home/manideepam/NOC/NOC.vhd}
elaborate NOC
read_sdc NOC_constraints.sdc
#read_sdc constraints_top.sdc
check_design NOC -unresolved
synthesize -to_mapped -effort medium
#write_sdf -timescale ns -nonegchecks -recrem split -edges check_edge > delays.sdf
write_hdl NOC > NOC_netlist.v
write_sdc NOC > NOC_rc_sdc.sdc
write_script NOC > NOC_rc_sdc.g
report power > NOC_power.rep
report timing -lint > NOC_timing.rep
report gates > NOC_cell.rep
report area > NOC_area.rep
gui_show
  • grasshopper
    grasshopper over 9 years ago
    Hi Manideepa,
    sorry but not enough details in your message to help out
    gh-
  • manideepa
    Thanks ! I have figured it out.
