  2. Logic Design
  3. problem with "REPORT RULE CHECK" command using conforma...
  • Subscribers 63
  • Views 7174
problem with "REPORT RULE CHECK" command using conformal
zohaibhassan
zohaibhassan over 7 years ago
I am using Conformal version 16.1 to run rule checks and fix the issues. I am able to successfully read the design, and see the issues using "report rule check" command. I am also able to waive the occurrence by going to the HDL Rule Manager, right clicking the rule and clicking "waive Occurrence" . I want to save these waived occurrence for the future so that I do not have to deal with these in the future versions of my design. I can see there is a -WAIved switch in the "report rule check" command but the tool throws an error that the option is unknown. It happens for [-NOHidden | -HIDden | -WAIved | -NOWaived] switches only. The same can be seen if I try to use "write rule check" command to write the -WAIved issues and it complains that it is an unknown option.  Please help what to do, either the help below is not correct, or I am not using it right. I have tried the exact case as it states below and I also tried small letters and capital letters but not help. I also tried TCL Mode using tclmode command and (report_rule_check with -waived parameter) but that fails aswell. I want to be able to waive issues, save them and apply it to the future version of designs to analyze only new problems. I tried the "man report rule check" and the output is written below.
SETUP> man report rule check
// Command: man report rule check
REPort RUle Check
[-All | -MODIfied | -RTL | -MODeling | -SDC | -LP | -CPF | -1801 | <rule_name*
[-SETTING] ]
[-File <filename> [<linenumber>] ]
[-FILTER <filter_expression> [-REGEXP]]
[-FILTERED_BY <filter_name*>]
[-ATTRibutes]
[-MODUle <module_name>]
[ | -Design | -Library]
[-SUmmary |-Verbose | -OVERVIEW]
[-STATUS < ALL | FAIL | PASS | IGNORED | NOT-APPLICABLE>]
[-DEFAULT_SEVERITY]
[-Ignore]
[-Note]
[-Warning]
[-Error]
[-CATegory [-XML <filename>]]
[-LIMit [<natural_number>]]
[-NOHidden | -HIDden | -COMplete
| -FILTERED_out | -NOFILTERED_out
[-HELP]
[-OCCURRENCE_COUNT | -MAX_PRINT_COUNT <limit>]
[-OLD_RULE_NAME]
[-RULE_SEParation <num>]
(Setup / Verify Mode)
  • zohaibhassan
    I tried it from the GUI aswell, I opened the "Modeling Rule Manager" clicked the "File" to choose "write rule check" button and it had a drop-down selection to choose Occurrences to write and I choose "waived occurences, regargdless of filters". It ran a command (write rule check tmp.txt -waived -replace) in the console and failed to execute with an error "Error: Unknown argument: -waived". It certainly seems like a bug in the tool
  • philcasey
    philcasey over 7 years ago in reply to zohaibhassan
     Thank you very much for the reply, I will work on the information you gave me.
  • zohaibhassan
    zohaibhassan over 7 years ago in reply to philcasey
    I found it that it is because of the low power license not being used, I used the switch "-lp"  in the command as "lec -verify -lp -dofile ./lint.do" and it worked for me. I still wish that the tool was reporting me that I do not have the correct license instead of simply complaining about the "Unknown argument", even the help did not mention that some of the switches require special license.
