  2. Logic Design
  3. Genus synthesis syntax Foreach
  • Subscribers 63
  • Views 16601
yann06
yann06 over 7 years ago
Hi all
Can we use such syntax in genus synthesis
Because I ve seen such syntax is not supported with latest version
The data_reg is a packed array of data_bit
foreach (data_reg.data_bit [idx])
The RTL work around is to perform for loop with $size(data_reg.data_bit)
Any help on it using foreach
BR
yann
  • GeorgeGG
    GeorgeGG over 7 years ago
    foreach item item_list
    I've used this and it worked for me
