  2. Logic Design
  3. Post-synthesis Simulation Failing when lp_insert_clock_gating...
  • Subscribers 62
  • Views 17273
Post-synthesis Simulation Failing when lp_insert_clock_gating true
GGobieski
GGobieski over 7 years ago
When I enable clock gating in my synthesis flow (using Genus 18.15), my simulation (using Xcelium) on the post-synthesis netlist fails. The simulation succeeds pre-synthesis and also if I remove clock-gating in the design. I use set_db  lp_insert_clock_gating true to enable clock gating during synthesis. I printed out some of the signals from the netlist and can see where it fails (it incorrectly writes a register). However, I am not sure how to solve this issue or what I should be looking for. Any help would be appreciated. Thanks.
  • GGobieski
    I have since solved the issue by changing the delay_mode in Xcelium to distributed.
