  2. Logic Design
  3. genus include `define file
  • Subscribers 62
  • Views 22735
saw235
saw235 over 6 years ago
I have a file that list all the `defines that is used in the current design. This file (define.vh) is generated, like so :
`define MACRO_1 5
`define MACRO_2 1'h0
... etc
But in genus when I run the command
read_hdl define.vh
read_hdl -sv top.sv
The tool work as if the defines never get parsed and returns with unreferenced errors. How can I resolve this? Do I have to include 'define.vh' in all the design files?
  • Igor Danilov
    Igor Danilov over 6 years ago +1
    You can parse your define.vh, convert it to a single string, and put it into the -define option of read_hdl command. Assume you have a file consist of only `defines. For example: `define SYNTHESIS…
  • Igor Danilov
    `define SYNTHESIS
    `define MACRO_1 5
    `define MACRO_3
    You can use this or something like it:
    proc parse_verilog_define_file {file_with_macro} {
      set fp [open $file_with_macro r]
      set file_data [read $fp]
      close $fp
      set data [split $file_data "\n"]
      foreach line $data {
        lappend processed_data [string map {" " =} [string trim [string map {`define ""} $line]]]
      return $processed_data
    set macro_string [parse_verilog_define_file "define.vh"]
    # result: "SYNTHESIS MACRO_1=5 MACRO_2=1'h0 MACRO_3"
    read_hdl -define $macro_string -sv top.sv
  • saw235
    saw235 over 6 years ago in reply to Igor Danilov
    Hi that worked, thanks a lot for the solution. I've used your solution in my script, but the last few days I tried the following and surprisingly parsing it as a list worked which I didn't expect because parsing them line by line did not work using read_hdl.
    read_hdl -sv {define.vh top.sv}
