  2. Logic Design
  3. map_to_mux
  • Subscribers 62
  • Views 17148
map_to_mux
Abhayk
Abhayk over 6 years ago
HI!
I want to use map_to_mux pragma for a particular logic in my code, which is in generate block.
module xyz
parameter P_IN_WIDTH= 100
parameter P_OUT_WIDTH =100
parameter P_XXX = 1
parameter P_ZZZ=1
parameter P_IN_OFFSET_WD = 10
input [P_IN_WD-1:0]  in_data;
input [P_IN_OFFSET_WD-1:0] in_offset;
output [P_IN_WD-1:0]  out_data;
generate
if (P_XXX == 1)
// cadence infer_mux "MUX"
// cadence map_to_mux "MUX"
begin : XXX
assign c_out = (in_data >> in_offset*P_ZZZ);
end
else
begin : YYY
assign c_out = (in_data << in_offset*P_ZZZ);
end
endgenerate
endmodule
