  2. Logic Design
  3. The CCD tools errors out when trying to set attributes ...
  • Subscribers 62
  • Views 3434
The CCD tools errors out when trying to set attributes "Unknown Command set_attribute"
Kapil Nagdive
Kapil Nagdive over 6 years ago
I am trying to Configure a CDC Rule Check by setting attributes, but it errors out saying "Unknown Command set_attribute"
I am giving following set of commands in the dofile:
add rule set -file ccd_default_cdc_ruleset.tcl
set rule_instance [find -ruleinst cdc_def_rs/cdc_checks/cdc* ]
set_attribute $rule_instance dff_sync_scheme "min 2 max 3"
run rule check cdc_def_rs
Please suggest if this is correct.
Thanks.
