  2. Logic Design
  3. Reporting non-RC gated flops
  • Subscribers 62
  • Views 18609
Max Bjurling
Max Bjurling over 6 years ago
The report_clock_gating command prints out a summary of the number of RC-gated flops, non-RC-gated flops, and ungated flops. Using the -gated_ff or -ungated_ff options the commands prints details about the gated or ungated flops.
Is there a way to get details about the non-RC gated flops without getting the details about all gated flops? Typically this report becomes very long if all gated flops in a design are listed (as with the -gated_ff option).
  • Dimo M
    Dimo M over 5 years ago +1
    Hi Max, as outlined in the article What does “Non-RC Gated Flip-flops” imply in the clock gating report? : " To see whether the flop is gated by user/Genus inserted CG instance, you can use the lp_clock_gating_is_flop_user_gated…
  • Dimo M
    Hi Max,
    "To see whether the flop is gated by user/Genus inserted CG instance, you can use the lp_clock_gating_is_flop_user_gated and lp_clock_gating_is_flop_rc_gated attribute respectively.
    Example:
    get_db insts -if {.lp_clock_gating_is_flop_user_gated==true}
    In Legacy_UI:
    filter lp_clock_gating_is_flop_user_gated true [find / -inst *]
    Dimo
  • Max Bjurling
    Max Bjurling over 5 years ago in reply to Dimo M
    Thanks Dimo, that was the solution to my problem!
    /Max
