  2. Logic Design
  3. VHDL IEEE Library not recognized by RTL Compiler or Gen...
  • Subscribers 62
  • Views 17708
VHDL IEEE Library not recognized by RTL Compiler or Genus
YuntaoLiu
YuntaoLiu over 6 years ago
I guess this is a dumb question but I didn't find any having the same issue as mine or any tutorial to guide me through this process...
I wanted to synthesize a design written in VHDL with either RC or Genus, but I got the same error (and the error repeats for each VHDL file...)
library IEEE;
Error : Missing token. [VHDLPT-672] [read_hdl]
: library clause requires ';', read <identifier> IEEE in file 'addroundkey.vhd' on line 46, column 9.
I guess I need to explicitly point to the IEEE library, which I am not sure how to do. Any insight would be greatly appreciated!
Yuntao
  • Dimo M
    Dimo M over 5 years ago
    Hi Yuntao,
    the message can be related to unsupported VHDL syntax from a newer VHDL version.
    You can try to set the following root attribute to enable 2008 syntax:
    set_db hdl_vhdl_read_version 2008 (Legacy: set_attribute hdl_vhdl_read_version 2008)
    Please refer to this article for some more information: Error VHDLPT-672 when reading VHDL
    I am moving the thread to the Logic Design section.
    Dimo
