  2. Logic Design
  3. How to add logic when compile
  • Subscribers 62
  • Views 13853
BaoP
BaoP over 5 years ago
Hi all,
I want to run simulation to check case the connection between modules be fixed 0/1 in specific time.
The idea is there will be logic (work same as isolation cell) be inserted in later phase to fixed value between 2 modules in specific time.
But I want to check it in early phase, when run simulation with RTL.
Example:
This checking apply to huge number of connection.
I came up with 2 idea:
1. Using Force command for all net of these net name connection. But there is a problem:
Connection A -> B: force at input of module B, logic inside at input of module A also be forced. I want to check only input of B be forced
2. Using UPF to define Isolation cell between module A and B. This same as my expectation but it is complex.
I wonder Xcelium support any solution for this case.
Thanks and Best regards,
