  2. Logic Design
  3. xmvlog: *E,MULPAK
  • Subscribers 64
  • Views 6298
xmvlog: *E,MULPAK
Yishay
Yishay over 4 years ago
I am trying to simulate a design with multiple packages .  I use the "-makelib/-endlib" options in xrun to specify all of the files .  However, I have run into a problem with packages.  In this case, I have 2  directories that both have a same file name  in their respective directories.
-makelib bt_core_r_rtl_lib_fullchip
    btrip_bt_rfif_shrf.sv
    bt_shrf_bus_pkg.sv
-endlib
-makelib bt_core_r_f2rf_lib
    bt_shrf_bus_pkg.sv
-endlib
When I try this, I get an error *E,MULTPK...Multiple (2) packages were found in searched libraries:
xmvlog: *E,MULPAK (btrip_bt_rfif_shrf.sv,50|23): Multiple (2) packages named "bt_shrf_bus_pkg" were found in the searched libraries:
-> found verilog_package bt_core_r_f2rf_lib.bt_shrf_bus_pkg:sv (VST)
-> found verilog_package bt_core_r_rtl_lib_fullchip.bt_shrf_bus_pkg:sv (VST).
import bt_shrf_bus_pkg::*;
How can i solve it ?
