  2. Logic Design
  3. Best library structure (worklibs)
  • Subscribers 63
  • Views 11783
Ryic
Ryic over 4 years ago
Hello,  I would like to ask for your expertise about setting for best library structure (worklib).
Will it be better to have multiple libraries ( library per part classification : resistor, capacitor  etc.. )
or few libraries ( Released ; includes all releases parts such as resistors, capacitors etc.. and  Customs that includes under dev and those that doesn't follow datasheet or IPC recommended land pattern due to test or special requirements )
Can you share the pro and cons that you see for the two options above
Or you can recommend a better way on handling the library structure (worklib)
