  2. Logic Design
  3. Genus : Tool coming out with "Killed"
  • Subscribers 63
  • Views 6007
sharadbrcm
sharadbrcm over 4 years ago
Hi ,
  I am a newbie running genus tool. I have a parameterized design that i am trying to elaborate and synthesize using genus. When i source the tcl script, it runs for a long time and then the tool crashes with just a message Killed on the console. The run logs also don't provide any more information as to what is causing this. Any insight into the same would be helpful.
Regards
sharad
  • sharadbrcm
    Snapshot of the error seen.
    // RTL CODE
    `define UNPACK_3D_ARRAY(D_WIDTH,COLUMNS,ROWS,PK_DEST,PK_SRC) genvar p_unpk_idr; genvar p_unpk_idk; generate for (p_unpk_idr=0; p_unpk_idr<(ROWS); p_unpk_idr=p_unpk_idr+1) begin for(p_unpk_idk=0; p_unpk_idk<(COLUMNS); p_unpk_idk=p_unpk_idk+1) begin assign PK_DEST[p_unpk_idk][p_unpk_idr][D_WIDTH-1:0] = PK_SRC[((D_WIDTH*COLUMNS)*p_unpk_idr+ p_unpk_idk*(D_WIDTH) + (D_WIDTH-1)):(p_unpk_idr*(COLUMNS*D_WIDTH) + p_unpk_idk*(D_WIDTH))]; end end endgenerate
    `define UNPACK_ARRAY(PK_WIDTH,PK_LEN,PK_DEST,PK_SRC) genvar p_upkidx_2d; generate for (p_upkidx_2d=0; p_upkidx_2d<(PK_LEN); p_upkidx_2d=p_upkidx_2d+1) begin assign PK_DEST[p_upkidx_2d][((PK_WIDTH)-1):0] = PK_SRC[((PK_WIDTH)*p_upkidx_2d+(PK_WIDTH-1)):((PK_WIDTH)*p_upkidx_2d)]; end endgenerate
    `define P_UPK_ARRAY(PK_WIDTH,PK_LEN,PK_DEST,PK_SRC) genvar p_upk_idx; generate for (p_upk_idx=0; p_upk_idx<(PK_LEN); p_upk_idx=p_upk_idx+1) begin assign PK_DEST[p_upk_idx][((PK_WIDTH)-1):0] = PK_SRC[((PK_WIDTH)*p_upk_idx+(PK_WIDTH-1)):((PK_WIDTH)*p_upk_idx)]; end endgenerate
    `define PACK_ARRAY(PK_WIDTH,PK_LEN,PK_SRC,PK_DEST) genvar p_pk_idx; generate for (p_pk_idx=0; p_pk_idx<(PK_LEN); p_pk_idx=p_pk_idx+1) begin assign PK_DEST[((PK_WIDTH)*p_pk_idx+((PK_WIDTH)-1)):((PK_WIDTH)*p_pk_idx)] = PK_SRC[p_pk_idx][((PK_WIDTH)-1):0]; end endgenerate
    `timescale 1ns/1ps
    module product (
    clk,
    rst_n,
    data_in,
    dval,
    weight,
    bias,
    ready,
    data_out,
    done
    parameter IN_WIDTH = 256;
    parameter OUT_WIDTH= 20;
    parameter D_WIDTH = 8;
    localparam [1:0] IDLE=2'b0, CAPTURE = 2'b1, CALC = 2'b10, PUSH_OUT=2'd3;
    input clk;
    input rst_n;
    input signed [D_WIDTH*IN_WIDTH-1:0] data_in;
    input dval;
    input signed [D_WIDTH*IN_WIDTH*OUT_WIDTH -1 :0] weight;
    input signed [D_WIDTH*OUT_WIDTH -1:0] bias;
    output reg signed [D_WIDTH*OUT_WIDTH-1:0] data_out;
    output reg done;
    output reg ready;
    reg calc_completed;
    //wire clk;
    //wire rst_n;
    //wire signed [D_WIDTH*IN_WIDTH-1:0] data_in;
    //wire dval;
    //wire signed [D_WIDTH*OUT_WIDTH -1:0] bias;
    //wire signed [D_WIDTH*IN_WIDTH*OUT_WIDTH -1 :0] weight;
    //reg signed [D_WIDTH*OUT_WIDTH-1:0] data_out;
    //== Unpack the weights and biases
    wire signed [D_WIDTH-1:0] w [IN_WIDTH-1:0][OUT_WIDTH-1:0];
    wire signed [D_WIDTH-1:0] b [OUT_WIDTH-1:0];
    wire signed [D_WIDTH-1:0] d [IN_WIDTH-1:0];
    wire signed [D_WIDTH*OUT_WIDTH-1:0] dout_wire;
    integer ii;
    integer jj;
    reg signed [D_WIDTH*IN_WIDTH-1:0] r_data_in;
    reg signed [2*D_WIDTH -1:0] prod;
    reg signed [D_WIDTH-1:0] outp [OUT_WIDTH -1:0];
    reg signed [D_WIDTH-1:0] temp;
    reg [1:0] cur_state, nxt_state;
    `UNPACK_3D_ARRAY(D_WIDTH, IN_WIDTH, OUT_WIDTH, w, weight)
    `UNPACK_ARRAY (D_WIDTH, OUT_WIDTH, b, bias)
    `P_UPK_ARRAY (D_WIDTH, IN_WIDTH, d, r_data_in)
    `PACK_ARRAY(D_WIDTH, OUT_WIDTH, outp, dout_wire)
    always @(posedge clk or negedge rst_n)
    begin
    if (rst_n == 0)
    cur_state <= IDLE;
    else
    cur_state <= nxt_state;
    end
    always @(cur_state or dval or calc_completed) begin
    case (cur_state)
    IDLE : begin
    if (dval == 0)
    nxt_state = IDLE;
    else
    nxt_state = CAPTURE;
    end
    CAPTURE : begin
    if (dval == 1)
    else
    nxt_state = CALC;
    end
    CALC : begin
    if (calc_completed == 0)
    nxt_state = CALC;
    else
    nxt_state = PUSH_OUT;
    end
    PUSH_OUT : begin
    nxt_state = IDLE;
    end
    endcase
    end
    begin
    if (rst_n == 0)
    begin
    r_data_in <= 0;
    ready <= 1;
    calc_completed <= 0;
    end
    else if (dval == 1)
    begin
    r_data_in <= data_in;
    ready <= 0;
    end
    end
    begin
    if (rst_n == 0) begin
    for (ii=0 ; ii < OUT_WIDTH; ii = ii +1) begin
    outp[ii] = 0;
    end
    done <= 0;
    end else begin
    case (cur_state)
    IDLE:
    begin
    for (ii= 0; ii < OUT_WIDTH; ii = ii +1)
    outp[ii] = 0;
    done <= 0;
    ready <= 1;
    ii = 0;
    jj = 0;
    end
    CAPTURE:
    begin
    done <= 0;
    end
    CALC:
    begin
    prod= w[jj][ii]*d[jj];
    outp[ii] = prod[D_WIDTH+4-1:4] + outp[ii];
    if (jj == IN_WIDTH -1) begin
    jj = 0;
    outp[ii]= outp[ii] + b[ii];
    if (ii == OUT_WIDTH -1) begin
    ii = 0;
    calc_completed <= 1;
    end else begin
    ii = ii +1;
    end
    end else begin
    jj = jj +1;
    end
    end
    PUSH_OUT:
    begin
    data_out <= dout_wire;
    done <= 1;
    end
    endcase
    end
    end
    endmodule
