  2. Logic Design
  3. cadence Digital design
  • Subscribers 66
  • Views 12923
blossom
blossom over 4 years ago
Hello everyone,
Good morning all,
 while I was pasting the command in scriipt file, i have the following error.
cadence@cad07 xorgate]$ genus _f script.tcl
bash: genus: command not found...
code:
module XOR_Gate(
  input A,
  input B,
  output Y);
  assign Y = ~A&&B || A&&~B;
endmodule
Test_code:
// Code your testbench here
// or browse Examples
module XOR_Gate_tb;
  reg A;
  reg B;
  wire Y;
  integer i;
  XOR_Gate inst(.A(A), .B(B), .Y(Y));
  initial begin
    $dumpfile("dump.vcd");
    $dumpvars;
    #100 $finish;
  end
  initial
    begin
      A <= 0;
      B <= 0;
      $monitor ("A=%0b B=%0b Y=%0b", A, B, Y);
      for (i=0; i< 4; i= i + 1)
        begin
          {A, B} = i;
      #10;
        end
    end
endmodule
  • MTYM
    MTYM over 4 years ago
    It appears you do not have genus in your executable path.
    type which genus to your shell.  I suspect it will return nothing;
    cadence@cad07 xorgate]$ which genus
    Then type echo $PATH
    and it will tell you the directories that are in your path.  Likely you are missing the one where the Cadence tools are installed.  Likely your CAD manager can help you out.
    cadence@cad07 xorgate]$ echo $PATH
    /bin:/usr/bin:/sbin:/usr/sbin:/usr/X11/bin:/usr/local/bin
