  2. Logic Design
  3. Gate-leve sim, sdf back annotation warnings
  • Subscribers 61
  • Views 16319
admin
admin over 18 years ago
I am running sdf-back-annotated Gate-level sims. During ncelab, I see the following warnings: 1. ncelab: *W,SDFNEP: Failed Attempt to annotate to non-existent path (IOPATH CP Q) of instance :DUT0.u_core.u_cfg.u1_xxxx_apb.bus_sync1.clk_gate_dest_bus_reg.latch of module c065std_cell_icgX10 <../TIMING/xxxx_netlist.sdf, line 329587>. The corresponding line (line 329587) in the SDF file is
<code>DELAY
    (ABSOLUTE
    (IOPATH CP Q (0.173::0.456) (0.183::0.486))
</code>
When I check the verilog for the standard cell library for the cell in question I see the following:
<code>specify
    (CP => Q) = (`c065std_cell_icgX10_CP_F_Q_F, `c065std_cell_icgX10_CP_R_Q_R);
    $setuphold(posedge CP, posedge TE, `c065std_cell_icgX10_TE_CP_SETUP, `c065std_cell_icgX10_TE_CP_HOLD, Notifier, ,EX ,CPdly, TEdly);
    $setuphold(posedge CP, negedge TE, `c065std_cell_icgX10_TE_CP_SETUP, `c065std_cell_icgX10_TE_CP_HOLD, Notifier, ,EX ,CPdly, TEdly);
    $setuphold(posedge CP, posedge E, `c065std_cell_icgX10_E_CP_SETUP, `c065std_cell_icgX10_E_CP_HOLD, Notifier, ,TEX ,CPdly, Edly);
    $setuphold(posedge CP, negedge E, `c065std_cell_icgX10_E_CP_SETUP, `c065std_cell_icgX10_E_CP_HOLD, Notifier, ,TEX ,CPdly, Edly);
    $width(negedge CP, `c065std_cell_icgX10_CP_PWL, 0, Notifier);
 endspecify</code>
Looking at this there does seem to be a path from CP -> Q. Can someone tell me why I still see this warning? 2. For the same module as above, I see the following warning ncelab: *W,SDFNSB: Attempt to annotate specify block data of instance :DUT0.u_core.u_cfg.u1_xxxx_apb.bus_sync1.clk_gate_dest_bus_reg.latch of module c065std_cell_icgX10, which has no specify block <../TIMING/xxxx_netlist.sdf, line 329591>. The corresponding section in the SDF file (line 329591) is:
<code>(TIMINGCHECK
    (WIDTH (negedge CP) (0.120::0.120))
    (SETUP (posedge TE) (posedge CP) (0.162::0.162))
    (SETUP (negedge TE) (posedge CP) (0.084::0.084))
    (SETUP (posedge E) (posedge CP) (0.295::0.295))
    (SETUP (negedge E) (posedge CP) (0.246::0.246))
    (HOLD (posedge TE) (posedge CP) (-0.115::-0.115))
    (HOLD (negedge TE) (posedge CP) (-0.071::-0.071))
    (HOLD (posedge E) (posedge CP) (-0.128::-0.128))
    (HOLD (negedge E) (posedge CP) (-0.082::-0.082))</code>
Looking at the afore-mentioned "specify" block can anyone help me understand the reason for this second warning? 3. Also the specify block contains $setuphold in an extended format. Can someone please explain the four fields after "notifier"? Thanks in advance Vishnu
